oharag
- Dec 16, 2002
- 73
Hello. I was wondering what type of coating is recommended for Alloy Steel 4140. We are currently using this for a bearing shaft. The tolerances are in the tenths so controlling thickness is critical after application of the coating. Is there anything out there that can coat this material without adding thickness? Or do I have to add a note: "Final dimensions are considered after applying coating.", and let the machine shop account for coating thickness?
I guess we could consider a stainless steel shaft so that corrosion is not a concern. Any thoughts on which type to use for a bearing shaft?
Sorry for my ignorance. Coatings have never been my thing. I know I should get more comfortable with the many options out there. Any links to good sites offering advice on the subject?
oharag
oharag
