Hydraulic Life Analysis
frankla
Automotive
Mar 20, 2003
5
How do you calculate cummulative damage on a hydraulic component (pump, etc.)? It is fairly straight-forward with structural components through the use of Rainflow analysis, level-crossings, etc.. However with hydraulics, if you have real-time pressure, flow and temperature measurements, how do you combine them into a damage assessment? Thanks in advance!
