MetalMickey
Materials
- Dec 6, 2002
- 18
I'm looking for a CRA grade with 1500MPa Yield in tubular or forged condition for use in a pipeline application. The item will only be exposed to seawater in the event of accidental extreme conditions but requires resistance all the same. Size of around 400MM OD with a maximum wall thickness of 5mm. Any suggestions since I seem to have topped out the Inconel grades already. Weldability is not required, but machinability is.
Many Thanks,
MM
Many Thanks,
MM
