Fuel Tank Sloshing
SPIGUY1
16
We're having trouble with sloshing impact damaging the fuel level sender (missing float arms, bent supports or supply tubes, inaccurate readings, etc.) in large tanks used in off-highway equipment. Most of the tanks are steel, baffled, with tri-angular corner supports based on pre-existing tanks, yet we don't have a set tank design procedure. Does anyone have experience in this or can direct me to useful sites for info?
