Burdy
- Sep 4, 2002
- 52
There appears to be a problem with Duplex Stainless Steel and Graphite corroding when in contact with sea water.
As requests for products with this combination have statements that the graphite must have a barrier on the graphite to prevent contact with the water, I believe that this is to try and stop Galvanic corrossion!
Is anyone aware of any actual documented failures or tests where this is confirmed.
Any assistance in this area regarding these or any other metalic material in combination with Graphite causing the same effect would be appreciated.
Many thanks
B
Many thanks
B
