Gatorboy
Computer
- Aug 13, 2003
- 4
Perhaps someone can help or at least guide me in the proper direction with my bridge-building decision/design. This is a large post, so I hope I don’t lose a lot of you from reading it because of its length.
OVERVIEW:
I have a piece of property in Fallston, Maryland that has a stream running the entire width of it, and where my house (someday) will be built is on the far side of the stream. I need to build a bridge that will be strong enough to allow fire trucks to cross or I think getting insurance will be a foregone conclusion. I would also like it to be strong enough to handle the occasional cement truck.
I have contacted one structural engineer who came out to my property, but I he never came up with any ideas on his own – I was coming up with several scenarios, and all he said was, “Yes, you could do that”, and in the end he said he would go back to his office, make some calls and get back to me with a quote. Well, he quoted me $2000 to come up with some plans, but still had not determined the best plan of action or design to be taken. I turned down his offer, and have been having a hard time finding a decent Structural/Civil Engineer in my area with experience in bridge designing. There are a couple large firms who said that my project was too small for them to work on. Where can I find a listing of these guys (or gals) to give them a call? I’m not trying to be stingy, I just want someone who KNOWS what can/can’t be done.
PRE-REQUISITES:
I do not want to touch the water in the stream, for if I do, then the Army Corps of Engineers will need to get involved, and I don’t want to have to deal with them. So the abutments need to be made on the outside of the banks, and no use of box culverts in the stream will be considered.
SPECIFICS:
- The bridge would span approximately 30’-40’ depending on how far away from the stream banks I put the abutments.
- There is a 4’ delta in height from the low and high side of the stream banks.
- The low side of the stream bank lies in a 100-year flood plain
- Pictures of location:
MY (remedial) DESIGN THOUGHTS:
- I want to build 95% of this bridge by myself – so simplicity is key.
- 4 steel I-beam stringers (size I have no clue), but more than 4 is probably needed.
- One lane bridge, so I am thinking the bridge should be 10-12’ wide
- Decking would be 8x8’s or railroad ties
- I want to build a timber footer and timber-bent abutment on the low side for it is very rocky and should keep costs down from needing big excavating equipment for digging. A picture of my thought is found at: (Scroll down to Figure 7-6)
- The abutment on the high side would be made of a timber-pile abutment (same web page Figure 7-7)
- I am totally in the dark about the size of the I-beams needed, and even if my ideas can produce a bridge to fit the rating requirements.
All help will be greatly appreciated.
:: D A V E H O F F M A N N
:: g a t o r b o y
OVERVIEW:
PRE-REQUISITES:
SPECIFICS:
:: g a t o r b o y
