andyinlouisiana
Petroleum
- Dec 18, 2002
- 3
i have some shafer actuators that i am repairing and i need help with model numbers. i can't read the serial numbers due to sand blasting, painting, and just lack of tag. i have a manual hydraulic pump on one that has two shafts for the pump with a selector for witchever shaft u would want to use. i was told u use the small shaft to get the valve to operate (ie ball break of off seat seal) and then use the big shaft to open/close the valve faster and with less stokes. i am having troble finding manuals and part numbers for a seal kit. i need to find a site with information on this type of pump.
thanks in advance for the help
andy
andy
