Metering valve for Alumina
mtsii
We have an application that we need to regulate the amount of Alumina flowing into an isostatic press. Regulation of quantity can be as simple as timing the opening of the valve. Amount of powder needed varies by end component produced. Powder is fed from hopper and is free flowing but abrasive (will probably need ceramic valve lining). Inlet can be upto 3/4" outlet should be 3/8" to 1/2" but this is not critical. Can anyone point us in a direction where to start, (manufacturers etc.) requirement may be upto 180 units. Any ideas?
Sid Smith
I would recommend that you contact GGOSCO Engineering Inc.
They can be reached at,
1272 Speers Rd. Unit 4
Oakville, ON, Canda
L6L 5T9
P: 905-825-2627
F: 905-825-4051
sales@ggosco.com
Give them a call and ask to speak to Chris and I am sure that they will be able to help you out. They have handled several applications very similar to yours and will be able to offer some possible solutions.
