PacificSteve
- Dec 22, 2001
- 84
OK experts, here is a challenging one.
I need to pump 1200GPM at 20 TDH saltwater at 70F, on a continuous basis.
I am leaning towards a 316SS or Fiberglass type pump (at least until I hear from the pros).
Main question -- can anyone hone me in a mnaufacturer that is likely to make a suitable pump with good efficiency (say 78% or better) in the expected range.
Pump has to lift 2 to 4 feet depending on tide. Source is a salt water well, so water is pretty clear. I don't want to use any checkvalves, and it does run continiously, so once primed, it should be good to go.
Thanks to y'all, from Hawaii, PacificSteve
