581127
- Aug 30, 2002
- 8
I have a question about the low carbon steel vessel, 16mm wall thickness in which there is a peddler. The vessel was heated by burning oil. The medium is caustic soda with some sodium sulfite, temperature is 330-350¡æ, normal pressure.
The vessel was badly corroded locally using for about 30 days. After replacing, nearly the same place on new vessel was corroded again.
My question is:
1.Why did corrosion occur locally? Is it related with pudding? How can I prevent the corrosion?
2.What is the corrosion mechanism?
3.Who can tell me where I can find the relative information?
Help me please
My question is:
Help me please
