gearman1234
- Dec 3, 2002
- 104
I have a gear to be shaved with profile and a lead crowning. The material is 4140. Gear Data 30T, 12 dp, 14.5 PA, Standard tooth thicknes,The base hardness required is 28/32. Since the batch qty is very less I am thinking of shaving the gear, thru' harden to 28/32 and induction harden to 50/55 as per dwg. Th dwg requirements are base hardness 28/32 and teeth hardness 50/55.
I was just wondering how much distortion would be there with double heat treatment. Required finish gear quality is AGMA 8, which is not stringent.
If I start with having heat treated material 4140 with 28/32 hardness and then hob it and shave it and then induction hardnen it, I may have a problem in shaving 32 Rc hard gear and the shaving cutter may not retain the profile. That is what is my opinion. If anybody else has any experience with shaving hard gears upto 32 Rc, then I would like to know about their experience.
