turbo2omni
My goal is to build a High street tired 12'sec car and get somewhere in the nieghborhood of 40 mpg. and don't doubt me the last project was a 86 GLH Dodge Omni. ran 13.4 all day long and averaged 35 mpg. oh yeah and the whole car was put together with junkyard parts for less than 1000 US dollars.
The current project car is a 1985 Shelby Charger running a 2.5 turbo engine.
The ??? I have is why have I never seen a venturi setup on the exhuast side of things. The thought (may be way off base but.....) is to take a "ram air" style duct from the front of the car and run this ducting towards the rear of the car. At some point along this path the exhuast system would "T" into this pipe, so that given enough air volume and speed a suction would be created on the exhuast system.
The problem I am trying to overcome is that a large turbine side A/R is laggy and has some effect on the fuel economy. and using a stock .48 A/R leads to 45+ psi of pressure in the exhuast manifold, in my particular set up. So in theroy if a "large" enough suction could be created I could get by with a smaller turbine A/R and trick it into thinking it was bigger than it is.
??How am I wrong ????
Or how fast would I have to go for this to work
