Low Heat Distortion Properties in Glass filled PET
arrondee
Materials
Aug 22, 2003
6
I am making a glass filled PET compound on a twin screw extruder. Properties are good except for an extremely low HDT value of approx 80 C instead of 215 which commercially available grades have. I still get this low number even when I use an alternative grade of PET. Strand length in the compound is good, no excessive breakage.
Does anyone have any ideas on how to improve this property?
80 deg C is a low HDT for PET, even unfilled. Are you useing homopolymer or copolymer, is it crystalised or amorphous. is it PETG.
Many beverage bottle compounds are amorphous copolymer.
Are you useing a glass fibre with good aspect ratio and suitable surface coating or sizeing agent
pat
