dozer
- Apr 9, 2001
- 502
Is it necessary to isolate a 6061-T6 aluminum gusset from a galvanized steel beam to prevent galvanic corrosion (or for any other reason?) This is the framing in a roof. It shouldn't be directly exposed to the weather, however the sides are open so it will not be in a controlled environment either.
Would a thin piece of of 304 stainless steel between the aluminum and steel help or hurt?
If it does need to be isolated, what is recommended?
