EIT2
- Apr 9, 2003
- 110
The new addition will be imposing a new drift load on the existing lower roof, composed of the following spec on the 1956 second floor plan:
PENN STEEL 41000 J14 - 24" oc
(The "41000" could be "#1000"
I need to investigate the existing capacity.
I have the SJI 60-year manual 1928-1988. In it, I have found SJ-Series from 1955-1959, and J-Series from 1961-.
Can anyone provide info on "PENN STEEL"?
Can anyone explain the 41000 (or #1000)?
Thank You!
Thank You!
