JoeSenihcam
- Aug 13, 2003
- 4
I currently have a machine that runs on 110 VAC. The problem is that it is going to pull too many Amps, so I am thinking of running it on 220 VAC. All of the conponents can run on 220 VAC with the exception of the Stepper moter drivers. I would like to know if there is any way to run 110 VAC out of the 220 that I will be bringing into the box? I realize that one of the legs of the 220 is 110 but I don't know where to get the ground and neutral at that point.
Thank you for any help you can offer.
