Bozis
Chemical
- Mar 6, 2003
- 2
Does anyone know of a simple way to monitor if a safety valve has lifted? Most of our safety valve vent directly into a flare header making it difficult to determine if one has lifted. One way is to put a bursting disc on the discharge side of the safety valve. This solution is however expensive to retrofit on an existing plant. Any ideas ?
