opticsman
Industrial
- Jun 4, 2002
- 58
Can anyone suggest the best material ( or composite ) for a thin-walled tube? The tube must be non-rigid i.e. very flexible/springy, wall thickness less than 0.3mm, melting point above 150 deg C. Not easily torn. Item would be similar to a catheter tube, only much thinner.Many thanks.
Opticsman
Opticsman
