The top plate attachment of a plywood shearwall is accomplished using angle clips or toenails. I have seen these clips or toenails only specified over the length of the plywood shearwall. My question is this:
Since the angle clips or toenails are transferring the shear (seismic or wind) into the double top plate (the strut) shouldn't the angle clips or toenails be spaced along the entire shear line instead of only over the length of the shearwall?
