samlukeben
Petroleum
I would like to assess the likelyhood of galvanic corrosion taking place between a High Alloy super duplex steel (Alloy 255) and a Grey Cast Iron in a marine environment. I understand that the galvanic potential is related to the "nobility" of the metals in question. However, I would just like to now if it may be a problem? and if so what measures I should take to mitigate the risk....many thanks in advance.....
