Countersinks conversion to Pro-E
MartB
Industrial
HELP.. I need somebody Help, not just any body Help.
When I convert from SolidWorks 2001 to Pro-E I cannot unbend my sheetmetal parts once they are in Pro-E when they have countersinks.I have tried different things. Even making countersinks with a hole and a cut extrude with a draft angle. I'm THAT desperate. Is there anybody out there with a solution.
Thanx a million.
Marty
Marty,
Go to comp.cad.solidworks newsgroup. Someone there can help you better, since no one replied to your post here.
Also check out & These are two very good threaded sites if you have to deal with a firewall and can't get to a newsgroup.
Hope that helps,
Scott Baugh, CSWP :-)
George Koch Sons,LLC
Evansville, IN 47714
sjb@kochllc.com
