thebadgerette
- Jun 5, 2001
- 5
I'm very new to Solidworks and trying to figure out how to do some sheet metal work.
I decided to play with corner variations, and while I know how to SHELL and RIP which will give me a simple sheet metal box with butted edges I decided I wanted a more finished corner and would like to add a bend around tab to the corner.
How do I modify the sheet metal flat sketch to do that? I can't seem to add to the corners, I can't seem to cut back the flat design so a tab can be added; everything I've tried gets me a "this area is too complicated" error message from solidworks 2K .
I could, I guess, go back to the Sketch 1 feature and reshape the rectangle, adding the flanges and all, but I think there's just *got* to be a better way to do this. Figure the boss liked the butted corner, then changed his mind and wanted wrap around tabs; I do NOT want to redraw the shape from scratch, that's the AutoCad way to do it.
