Determining the amount of material over time
tegefe
Industrial
Sep 26, 2002
28
If I were to spray a glue mixture onto a flat surface at a controlled and constant rate of flow, with a constant mixture viscosity, and the shape that is formed from the spraying forms a circle how can I approach solving for the amount of material that I have applied at t=1 sec, t=2 sec, t=X sec, etc.
Thank you in advance
