Operational Ampifier
iconchris
Chemical
Aug 8, 2003
7
I am trying to dive a proportional control valve from a PLC. The analog output from my PLC is a (low power) 0-10 Volts signal. The valve requires a 0-15 VDC (150 mA) signal. I know I can build a relatively cheap an easy Op Amp to accomplish this. I would prefer to get an off the shelf Din Rail Mount Unit that could handle multiple channels. Does anyone have any thoughts on this?
Thanks for the help.
check Phoenix Contact for
amplifier modules.
rodar
You may get a better response if you post this question in the Programmable Logic Controllers (PLC) Forum.
I have decided to have a supplier manufacture a PCB with multiple channels. It seems like the easiest and cheapest route to take.
