spacer ring beween taper roller bearings
smaty
25
For creating clearance between two taper roller bearing (face to face), Shall we use spacer ring bigger/smaller than distance between two outer rings of bearings?
For example if we have 35mm distance between two outer rings, shall we use 35.05mm or 34.95mm spacer ring??
