ads22
- Nov 3, 2003
- 20
I'm just starting to research building a racing engine. This is based on a 70s - 80s VW 8V watercooled (Rabbit, Scirocco, Golf etc.) engine. The class rules specify an 11:1 CR and an unmodified combustion chamber so the basic design is pretty fixed. A flat top piston with the right head milling will give approximately the correct CR.
The stock combustion chamber with a flat top piston will give a pretty big squish area - maybe 70% of it opposite the spark plug and 30 "behind" the spark plug.
Finally to my question - what would be a reasonable "squish gap" - ie clearance between piston top and head face? And should it be uniform or tighter opposite the spark plug?
My previous race engine building experience was with unlimited CR engines with very short stroke and more open wedge chambers where we were fighting for CR and got everything as close as we dared. But that's not the case here - there should be no problem getting the max allowed CR.
I can "visualize" - ie gut feel - that possibly there is such a thing as too much squish from a turbulence point of view. Also I would think that a very tight squish would produce some pumping losses.
Obviously the optimum would be discovered empirically on the dyno. And more time and $$ than I've got.
Anybody got an opinion or any rules of thumb as a good starting point?
Thanks!
Thanks!
