SoledWorker
- Aug 20, 2001
- 50
I've got an old "AT" power supply that I salvaged in the hope of using it as a clean 12V source. This particular unit is from the days when a switch tied into the power supply was used to turn the computer on, unlike the newer ones where the motherboard turns the power supply on.
I did some research on the internet to find out more about these devices and learned that they shouldn't be run unless connected to a motherboard. Does anyone know if it is possible to simulate the load of the motherboard with a simple resistor, or is the motherboard providing some kind of feedback that means the powersupply can't be used for my purposes? (I'm just after a source of 12V for hobby purposes, charging batteries without using the car battery/cig lighter)
