jhpf
- Nov 4, 2003
- 3
Our firm provides consulting engineering services to a several municipalities in our state. Sometimes, we are asked by local land use commissions to review the structural, hydraulic, and foundation aspects of private driveway bridge applications. These bridges typically span watercourses and can span as much as 50'. Often times, steel stringers are used with (non-composite) timber deck.
Unfortunately, the engineering work in support of these driveway bridges is minimal at best. For instance, bridge rail systems might be relatively custom and without supporting computations, never mind be of a crash-tested design. Stringer design computations do not often include contributing deadload. Concrete abutments and wingwalls are not typically designed to be stable on a per unit of wall length basis. Reinforcing steel is not developed properly. Proper hydraulic analysis using such models as HEC-2 or HEC-RAS are not typically included. Scour analyses are never included. Sometimes, an applicant will submit HY-8 or try and compare his proposed waterway area to the waterway areas of the closest up and donwstream structures.
While it may seem excessive to some applicants, we typically suggest to the municipal land use commission that we are working for, to see to it that proper engineering standards of practice go into the design of even private driveway bridges.
Does this seem excessive to anyone? Has anyone had similar experience, and if so, what have you required of the applicant?
