Carburize
Materials
- Sep 23, 2002
- 702
If a steel can be heat treated to different strength levels how does this effect fatigue performance in a corrosive environment?
For example in oil field applications it is possible to heat treat some alloys to 100,000 or 150,000 psi yield strength. Under fatigue conditions in air the higher strength material has a higher fatigue limit but what is the effect of exposing these two materials to salt water or hydrogen sulfide?
