tgreenwood
Chemical
Could someone please explain the difference of what appears to be two different subtypes of 316L S/S. (DIN 1.4435 and DIN 1.4404) Also, does BPE subgroup of ASME recognize DIN 1.4435 as a Pharmaceutical or Biotech grade? Would a problem occur if a 1.4404 fitting was unknowingly welded to a 1.4435 valve body?
When I am purchasing fittings to modify valves they are usually listed as 316L. I want them to also be DIN 1.4435, will I need to request a certificate or MTR?
Thanks in advance
Thanks in advance
