I have had a Powerdyne Supercharger with an internal belt drive similar to a Cam drive belt on OHV engines. The belts seem to break due to both heat and tension. I have tried Kevlar belts, which seem to last longer, but still break. I have heard that Neoprene rubber is only good to 150* F, could this be the failure mechanism? Are there any stronger materials or better belts or materials available?
