Have turbocharged fuel injected engine on SF901 with very erratic pressures during run up, particularly worse within rpm ranges. Engine is fired sequentially and alternates rails. Have checked supply and system all the way to engine, great volume, even pressure is stable up to our decided limit of 5 bar. Once engine is added pressure swings of 1.5 bar are registered on guage and in expansion box to test data. All air is bled from system. Engine power does vary with fuel pressure and is very unrepeatable. Fuel is fed from engine stand with high pressure pump into tee, then to each rail assembly, thru rails to regulator, return to surge tank on dyno stand. Adding damper resulted in condition becoming WORSE! All lines are -6 AN, all 90 degree fittings are bent tube. Also present if manifold disconnected from fuel pressure regulator, or routing is changed to series loop. Alternate fuel pump and regulator were also tried in vain. Any suggestions welcome.
