mgagne
- May 3, 2001
- 6
I want to checked bolts in a capacitor bank structure for seismic and wind load cases. I use the IEEE 693-1997 standard which refers to the AISC Manual of Steel Construction ASD. Someone tells me to use allowable stresses of 0.17*F_tu in shear and 0.33*F_tu in tension which are supposed to came from the ASD standard. That seams to be low compare to what I have found in ASD. I would like to know if those values are used in practice and where I can find the factors 0.17 and 0.33. Is the allowable stress in tension is reduced to take into account the shear stress??
Martin
Martin
