3Pipes
- Apr 2, 2003
- 6
Please could I ask for an opinion.
IBC 2000 1602 Defines an EBF as
"A diagonally braced frame in which at least one end of each brace frames into a beam a short distance from a beam-column or from another diagonal brace".
If a brace was eccentric at both ends, would it still be classed as an EBF as defined by IBC 2000. ie. framed into a column at a distance above / below the nearest beam / column connection.
To stick my head on the block, I would say a braced frame with braces eccentric at both ends is not an IBC 2000 EBF thus "Design Coefficients" listed in Table 1617.6 and others parts of are not relevant and thus cannot be used to support the design. (The column "links" in this "design" are not specially strengthened or modified).
I would value your views.
