IBC 2000 Pressure Vessels on skirts.
3Pipes
6
Please could anyone comment.
Assuming that a vertical pressure vessel on a skirt on its own foundations is classified as a “non-building structure” covered by 1622, where in IBC 2000 does the over strength factor Omega_O apply ? NEHRP 2000 Paragraph 14.7.3.3.a makes quite clear and logical reference about use of Omega_O in reference to connections and anchor strength. Logically it should also apply to IBC 2000 ?
