MacGyverS2000
I have an ongoing thread in the "Circuit Engineering" forum discussing potential methods to achieve a stable supply voltage. The kicker is no matter what method I come up with, I still need to dissipate 6-8W in the conversion process (using switching converters at 85-90%efficiency, linear regulators, etc.). From previous circuits I know even 1-2W is an amount of heat I can't hold in my hand without buring some flesh after a few seconds, so 6-8W is a scary thought.
My question to you guys is, how do I safely dump this kind of heat? Or better yet, is it even something I should worry about? The circuit will go into a fairly small plastic package (let's say 3" x 3" x 1"
, will be used in an automobile, and will ocassionally be picked up and held for extended periods. Would it be reasonable to use a heatsink within the case and allow holes for ventilation, or am I out of my gourd thinking I can dump that much heat?
The only saving grace I can think of is a car stereo with integrated amplifier. Even today's aftermarket stereos are 25-30W rms and their efficiencies have to be less than only a switching regulator.
