Forming polypropylene?
Tofflemire
Marine/Ocean
Oct 3, 2002
312
Hi All
I would like to know if it is possible to heat and form a polypropylene part. I have a half sphere and would like to have a flat surface on it. Can I apply heat to soften the material and form a flat surface? The thickness of the material is approximately 5/32". Do I have to be concerned with property changes? I.E. spidering, cracking and weakening of the material?
Tofflemire
Polypropylene is one of those wonderful materials known as a thermoplastic. You can heat it, melt it, and resolidify it without changing its chemical properties. You should be able to take a flat piece of metal, heat with with a blow torch and press it down on that ball to get the effect you're looking for. Polypropylene has a fairly low melting temperature, and it's not advisable to heat the whole part. You'll likely get deformation.
aspearin1
PP is a high shrinkage material, and while it can easily be thermoformed as described correctly above, it is prone to differential shrinkage and therefore warpage, so you will get a flatish surface, but truely flat will prove difficult if not impossible. It really depends on just how flat you want.
pat
