Snowmann
- Nov 17, 2003
- 5
I have a pinion spur gear that I need to mate a new gear with. It is an 8/10 Fellows Stub tooth with 9 teeth on a 10 tooth blank. Pitch diameter the # teeth divided by the diametral pitch. I know for Fellows Stub Tooth gears the numerator of the 8/10 diametral pitch is the one to use to establish pitch diameter (the 8), but what of the # of teeth? The pinion prints says the pitch diameter is 1.25. That means they were using the # of teeth for the blank size (10), not the actual # of teeth (9). Is this correct? I do not understand what 9 teeth on a 10 tooth blank means, and whether to use 9 or 10 to establish pitch diameter.
