gibsi1
- Dec 10, 2003
- 43
Our plant is looking to upgrade our sulfuric acid piping. Carbon steel is the current spec, which we will probably stick with for the transfer lines that handle only ~98% sulfuric at ambient temps with 40gpm. The problem area is our regen skids for our DI water systems. The mixing tees dilute the acid down to 6%, which produces a ton of heat. I looked at using Resistoflex multi-axis PTFE lined pipe, but the section after the mixing tee is 6". Does anyone have suggestions for some alloy that can handle this? We want to stay away from flanged connections, which is why I was looking at the Resistoflex multi-axis lined pipe. Maintenance would prefer an alloy that is weldable (field modifications). Thanks in advance!
