Joint Efficiency for Threaded Connections
Feartheturtle
1
From ASME Section VIII-Division 1 UG-27, it seems that joint efficiencies for pressure vessels only apply to welds and ligaments. What would the circumferential joint efficiency be for a threaded connection on the ends of a cylindrical tube? I am using this to find the minimum thickness of a shell under internal pressure.
If I understand your question regarding installation of two threaded connnections in a cylinder (e.g., tube) one on each end, I believe you need to read UG-36 thru 39 of ASME Section VIII, Div 1 regarding openings. Multiple openings are treated differently than single openings, which I believe is your case. The ligament efficiency deals with multiple openings, thus it has to be factored in the vessel wall thickness formula.
A single opening in a head or shell is treated in a different manner, as descibed in UG-36 thru 43. The issue concerning an opening in a pressure vessel is related to local reinforcement. An opening can be smooth bore or contain threads in UG-36 3) c).
Simply provide the minimum calculated thickness of shell plus corrosion allowance at the root of threads, add the additional wall thickness required by UG-31, add the thread depth and this is your minimum required thickness. Now add any minus tolerance on thickness to get the minimum nominal thickness.
prex
Online tools for structural design
