1
- #1
I am starting another thread hopping I will get some responses this time.
I have been searching for a good approach on the design of post embedment in concrete slab that varies in thickness from 4" to 7". ACI 6.3 discuss this subject but it does not in any way describe a method of design. The post is subject to a lateral load of about 640lb on the top of the post due to wind and due to the fact that the post is a member of a glazed railing. As you know the minimum load that the railing should be designed for is 50 lb/ft along the top rail and 200 lb at any point along the rail. However, when the railing is glazed railing and is subject to high wind pressure the load increases. Therefore, the embedment in concrete slab must be improved. How would you approach this problem?
