There is microcontroller for 2 inputs edge capture ?
Lanfeust23
CA
I'm looking for an ATMEL microcontroller which can do edge capture input on 2-inputs. I only found some ones which do edge capture on only one input but I need to do this on 2 inputs (I have two signals).
Thanks to tell me if that I'm looking for exists.
How fast response do you require? Can you explain your requirements ?
<nbucska@pcperipherals.com>
If you can use an additional IC you can clock a Flip Flop with your edge and clear the FF with an output bit.
In fact, my 2 signals (from an ADXL202 accelerometer) are PWM signals with a periode of 1ms. Moreover, the 2 signals are 'synchronized' because they use the same triangle wave reference in the duty cycle modulator.
If I am unclear again, here is the link to the application note of Analog Devices I'm speaking about :
I don't think you will be able to do real measurement:
I suggest calculate the required accuracy and I think
you will find that the ATMEL -- without additional hardware
is too slow.
I calculated, and with an acceptable accuracy I fixed myself, a 1MHz clock for the microcontroller will be right.
1µs in 1ms is 1 part in 1000. That is not very great resolution.
Perhaps you could just use the analogue outputs into a PIC chip with dual 10 bit DACs.
I know it's not a very great resolution but I think it will be enough. In fact,I can't do much better because after I will send information by RF (I need wireless application) and I'm limited by its bandwith (only 5kps).
Have a look at the Zilog Z8encore! I think it has three capture channels. The development system is almost free.
The Motorola 68HC11, DSP56800, DSP56300 series processors will all do what you need (assuming I understand your requirements correctly).
