WinCC V6.0 SP1 Problems
djhn579
Chemical
We have put in a new WinCC operating system. This program is far better than what we had in the past, but we do have a number of problems. Does anyone else have similar problems to what I have listed below? And if so, what did you do to fix the problems?
1.) Web Navigator is slow and locks up
2.) CCRTSLoader error when starting up while a PLC that triggers a global script is on
3.) When setting up a new client computer, everything in the project works except accessing data from the UA through the user archive table element ActiveX control
4.) Errors with tag values when transfering from tables to tags and between tags
These are the worst of the errors we are experiencing, and the company that set up the project don't seem to have a good idea on how to resolve them. Any and all help will be appreciated!
