itspcb
- Mar 24, 2004
- 6
I have a set of 8 off 22DP pa 20deg. gear cutters. One of them has a delta Sign (triangle?) with a 'T' in it. What does this signify?
In addition the d+f of this cutter is shown as 0.1 whereas the rest are 0.098", normal for US gears. Also the cutter is thinner than the rest. Visually it fits a test gear, but the symbol must have a reason.
Thanks in advance.
Peter B
uk
Thanks in advance.
Peter B
uk
