homebrewdude
- Jan 26, 2004
- 36
I am looking at some data for an existing gear we are using.
It is defined as a standard Stub Tooth gear.
(it currently mates with another stub tooth gear)
Is "stub tooth" considered a standard gear type?
Is the 'stub tooth" utilized to reduce wear on high loads?
Reduce wear due to gear alignment issues (lack of)
I would like to utilize this same gear in a new design using a rack.
Would I specify the rack teeth as "stub tooth" also?
any suggestions?
thanks
any suggestions?
thanks
