JoelMyers
- Mar 1, 2004
- 4
I am using PC/ABS for a plating application would like to check the molded-in stress of the part by a process similar to the following.
ASTM D 1939-84, "Determining Residual Stresses in Extruded or Molded Acrylonitrile-Butadiene-Styrene (ABS) Parts by Immersion in Glacial Acetic Acid"
I am not sure which acid I need to use for PC/ABS. Any help will be appreciated.
Thank you.
Thank you.
