hole annotation problem
Nuson
11
Inventor is having trouble showing hole annotation symbols correctly for me. I created a custom hole annotation to show what inventor does when it tries to place an annotation symbol: Does anyone know how to fix this? Thank you.
What do you mean, inv problem? I've tried changing demension style fonts to times new roman and verdana, but I'm still having the same problem :(
Ah that's probably it. The decimal, diameter etc.. symbols are represented by a font named AIGDT and AMGDT. Changing them to a font other than this will cause problems.
Make sure you even have these fonts on your system also. They sometimes get deleted when uninstalling software.
Sean Dotson, PE
Inventor Tutorials & More
Your Webbased mCAD Discussion
Awsome. That worked perfectly. Thanks Sean. I deleted some fonts a while back because I had alot of similar and seemingly useless fonts. Obviously, I did not realize that I'd be needing those two... Scarey how you knew which ones they were ;). THanks!
