Gauss2k
- Feb 27, 2004
- 49
Hello!
I have to ground several stocking silos made of 100% polypropylene fabric (the silos are filled with polystyrene beads). It doesn't contain any grounding wires included within the fabric. The silos are about 4x6x10 feets and their frame is made of metal pipes.
I am not familiar with static electricity and I wonder how much wires (connected to the ground) I should add on the silo's surface to remove most of its charges since I don't think that grounding only the frame will be enough.
And what kind of grounding rod should I use? (depth, size, etc) And what about the size of the gounding wire?
Gauss2k
Gauss2k
