Ahr35181
- Sep 8, 2003
- 80
I’d be interested to hear the views of others on possible electro chemical corrosion between Ex brass cable glands / copper sealing washers & Ex aluminium enclosures. Both Pirelli & Hawke recommend the use of nickel or tin plated glands, but one Ex panel manufacturer recommended using brass glands with silicone grease applied to the threads???
Thanks in advance,
Alan
Thanks in advance,
Alan
