What furnace vol. do I need?
op9
Industrial
Aug 18, 1999
111
I have to convert an existing LPG fired boiler to diesel and waste oil (mainly used lube oil from diesel engines) firing. The boiler is a firetube, but is a reverse flame furnace (ie a generally large diam. dead end furnace where the flame firing down the middle returns on itself, the gases flowing back around the inner periphery of the furnace and then through a convection pass. <br>I have had plenty of experience (mainly bad!!!) using waste oils and am aware of most of the pitfalls but here my question relates to this particular type of boiler furnace and how much furnace volume is required to enable an unrestricted flame to form and stay stable unaffected by the return flame or gas.<br>The existing NuWay (UK) package burner is firing at approx. 6000 MJ/ Hr. This is only an educated guess as there is no meter at present but hopefully will be installed before we are comitted. The present furnace backpressure whilst firing is about 12mbar. <br><br>The furnace dimensions are 795mm ID x 2440mm long before entering the convection pass tubes.<br><br>The oil burner I intend to use is an Oilon pressure jet made for firing waste oils with good diesel using 2 separate nozzles. Its usual published flame dimensions at<br> 6000 MJ/ Hr is 700mm max diam. x 2500mm long. and it is capable of firing against 14mbar backpressure.<br><br>I was hoping somebody had had experience with firing into these or similar type of boilers (originally a Swiss &quot;Ygnis&quot; design) and could confirm whether the furnace appears adequately sized or have you had to somehow narrow the flame? Unfortunately the boiler manufacturer (local) is not very helpful OR doesn' t know.<br><br>The new burner manufacturer says it should be OK, but as the job is on an island a long way from home and there is a lot of additional auxillary systems like pumps, heaters, tanks and pipework to install as well, I need to convince myself it will work before proceeding.<br><br>I would really appreciate any definite information or helpful advice maybe on expected flue gas volumes in the furnace and associated pressure drops.<br><br>Thanks in hope???<br>Rod Nissen.
